SANIX3D · Free 3D Printing Tool
3D Printer Electricity Cost Calculator
See what your 3D printer really costs to run each month and year, then bring your prints to life with our premium STL files, with new models every month.
Browse all models →
Homelander 3D printing STL model Elektra 3D printing STL model Shadowbound 3D printing STL model Kitana 3D printing STL model
See all our free 3D printing calculators 7 free tools, all in one place. See all calculators
See what your 3D printer really costs to run – per print, per month and per year.
Loading live exchange rates…
This free tool is the intellectual property of SANIX3D (www.sanix3d.com). The calculator is disabled because the attribution data was removed or modified.
Printer power
Average draw while printing, bed/plate heated. Standby is set below.
How much you print
– h of printing per month
Electricity price
Average household rate – check your latest bill.
If left on when idle. Typically 3-15 W.
Powered on but not printing.
Estimated monthly running cost
Per hour of printing
Per print
Per year
≈ Approximate result. Real power draw changes with material, bed temperature, room temperature and print settings.
Power values are measured averages while printing on popular printers (Bambu Lab, Prusa, Creality, Anycubic, Elegoo). A big share of the draw is heating the bed and hotend, so an efficient, well-insulated printer can noticeably lower these numbers. Electricity prices are approximate household averages per country – adjust to your own tariff for exact results.
Real prints, real detail
Real prints of our models – see the exact detail and quality you get before you buy.
Real 3D printReal 3D printReal 3D printReal 3D printReal 3D printReal 3D printReal 3D printReal 3D printReal 3D printReal 3D printReal 3D printReal 3D printReal 3D printReal 3D printReal 3D printReal 3D printReal 3D printReal 3D printReal 3D printReal 3D printReal 3D printReal 3D printReal 3D printReal 3D printReal 3D printReal 3D printReal 3D printReal 3D printReal 3D printReal 3D printReal 3D printReal 3D printReal 3D printReal 3D printReal 3D printReal 3D print
Popular categories
About the SANIX3D Electricity Cost Calculator
The SANIX3D 3D Printer Electricity Cost Calculator is a free online tool that shows what your printer really costs in power, per hour, per print, per month and per year. Pick your printer or type its wattage, set how much you print and your price per kWh, and it works out the running cost for you, in EUR, USD or GBP. It also handles standby draw for machines left on when idle. It is built for hobbyists and print farms who want to know the true energy bill behind their prints.
How to use the electricity cost calculator
  1. Pick your printer to set its average wattage, or choose Custom and type the watts from a power meter.
  2. Set how much you print, a usage profile or your own hours per day, days per week and average print length.
  3. Enter your electricity price, pick your country for a typical rate or type your exact price per kWh.
  4. Read the running cost, the monthly total plus per hour, per print and per year, and add standby draw if the printer stays on.
How much electricity does a 3D printer use?
A typical desktop FDM printer draws about 70 to 150 watts on average while printing, most of it heating the bed and hotend. A 120 W printer running 4 hours a day, 5 days a week uses roughly 10 kWh a month. Resin printers draw less, around 30 to 85 watts.
How much does it cost to run a 3D printer per month?
For a 120 W printer at about 87 hours a month and 0.39 EUR per kWh, running cost is around 4 EUR a month. Heavier use or a higher tariff raises it. This calculator gives your exact monthly, per print and yearly figures.
How do I calculate my printer power cost?
Multiply the printer wattage in kilowatts by the hours you print, then by your price per kWh. A 0.12 kW printer running 5 hours at 0.39 EUR per kWh costs about 0.23 EUR. The tool adds up months and years automatically.
Do 3D printers use a lot of electricity?
Not really. Most desktop printers use about the same power as a games console or a bright light bulb while running. The bed heater is the biggest draw. Over a full year of regular use it usually adds up to tens of euros, not hundreds.
Does standby power matter?
A printer left powered on but idle can draw a few watts around the clock, which adds up over a month. Enter the standby watts and idle hours in the advanced section to include it, or switch the printer off at the wall to avoid it.
How can I lower my 3D printing electricity cost?
Enclose the printer to keep heat in, lower the bed temperature where the material allows, print at efficient speeds, and switch the machine off when idle. An efficient, well-insulated printer noticeably cuts the running cost.
Related tools: add this to your full cost with the FDM Cost Calculator or price a sale with the Pricing Calculator. Live currency conversion uses the official European Central Bank rates.
