Halloween Pumpkins – STL Files
Halloween Pumpkins – now you can decorate your home with a 3D-printed pumpkin featuring various faces and emotions.
The project includes 8 pumpkins.
The printed pumpkin’s height is 10 cm (100 mm), as indicated in one of the images.
The pumpkin is hollow inside, allowing you to insert an LED or other light sources.
Recommendation – Do not use candles or other open flame sources to avoid fire hazards, as resin or plastic (PLA) ignites very easily.
These files can be printed with both SLA and FDM.
For FDM, minimal support is required.
You can print the models in any desired size.
STL files can only be downloaded from www.sanix3d.com .
#halloween #3DPrinting #STL Files #pumkins #sanix3d #emotion #holiday
Customer reviews on “Halloween Pumpkins – STL Files”
