SANIX3D · Free 3D Printing Tool
Resin 3D Print Cost Calculator
Work out the real cost of every resin print – resin, consumables, electricity and failures – then bring your prints to life with our premium STL files, with new models every month.
Browse all models →
Resin Print Cost Calculator
Real cost per SLA/resin print – resin, consumables, batch total and failure buffer.
Bottle prices reflect standard 405nm resin (1 L/1 kg) from Elegoo and Anycubic’s official EU stores – boutique or specialty resins (tough, water-washable, Siraya Tech, etc.) commonly cost more. Power values are based on official specs and independent measurements for popular mSLA printers (Elegoo Mars, Anycubic Photon Mono M5s, Elegoo Saturn). Consumable percentages are rough estimates for gloves, isopropyl alcohol and screen/paper filters – adjust to your own routine and prices.
Real prints, real detail
Real prints of our models – see the exact detail and quality you get before you buy.
Popular categories
About the SANIX3D Resin Cost Calculator
The SANIX3D Resin 3D Print Cost Calculator is a free online tool that shows the real cost of every SLA/MSLA resin print, not just the resin. Enter the volume per model from your slicer, your bottle price and consumables, then add electricity and a failure rate, and get an instant cost per model plus the full batch total, in EUR, USD or GBP. It is built for makers who sell resin prints, run a small print farm, or simply want to know what a miniature or statue really costs before curing it.
How to use the resin cost calculator
- Enter the print – volume per model in millilitres from your resin slicer, plus a supports allowance if the slicer volume does not include them.
- Set resin and consumables – bottle price and volume, plus a percentage for gloves, IPA wash and filters.
- Add electricity – pick your printer for average power, choose your country or type your price per kWh, and enter the total vat time.
- Set the batch – how many models share the vat run and a realistic failure rate, then read the cost per model and the batch total.
How much does it cost to resin 3D print a miniature?
A small 28mm miniature uses only a few millilitres of resin, so material cost is often just a few cents. A large bust or statue can use 50 to 150 ml. With consumables, electricity and a failure buffer added, a typical resin print lands anywhere from a few cents to a couple of euros per model.
How do I calculate resin cost per model?
Divide the bottle price by the bottle volume to get the price per millilitre, then multiply by the volume of your model. A 22 EUR bottle of 1000 ml is 0.022 EUR per ml, so a 40 ml model uses about 0.88 EUR of resin.
How much resin does a print use?
Your resin slicer (CHITUBOX, Lychee) shows the volume in millilitres for the whole plate. Divide by the number of models for per-model volume, or read a single model directly. Small minis use 2 to 10 ml, busts 30 to 80 ml, large statues 100 ml and up.
Why is the resin failure rate higher than FDM?
Resin prints fail more often – supports pulling off, suction cupping, under-cured layers or a cloudy FEP. A failure buffer of 10 to 20 percent spreads that wasted resin and time across your good prints, so the average cost stays realistic.
Should I include consumables and printer wear?
Yes for the true cost. Gloves, isopropyl alcohol and filters add up, and the LCD screen wears out after a few thousand hours. Consumables are a percentage of resin cost here, and printer wear is optional in the advanced section.
What does one litre of resin cost?
Standard 405nm resin runs about 17 to 30 EUR per litre from Elegoo and Anycubic. Tough, water-washable and specialty resins cost more. Enter your actual bottle price for an accurate result.
Related tools: try the FDM 3D Print Cost Calculator for filament prints, or the Scale Converter to resize models. Live currency conversion uses the official European Central Bank reference rates.
